Vashta
picture button does not work
Thu Aug 25, 2016 7:46 pm
All are in the title...
You specify in the BV6000'page that: Single click to access shooting mode ---> Doesn't work.
And the rest ..
Best regards,
Vashta
Re: picture button does not work
Fri Aug 26, 2016 8:32 am
Vashta wrote:
And the rest ..
Best regards,
Vashta
You are talking about the special camera button ?
Best regards,
Admin
Vashta
Fri Aug 26, 2016 10:54 am
Yes
sams
Fri Aug 26, 2016 8:11 pm
you need to long press the button to launch the camera application.
Awakekiwi
Sat Aug 27, 2016 12:38 am
You need to hold the button down for a few seconds first to open camera app, works for me..
SnuffThePunkz
Mon Aug 29, 2016 4:30 am
I have to hold mine like 5 seconds before it enables. Far to long to be practical.
They need to speed it up, drastically.
gonta
Mon Aug 29, 2016 8:40 am
Actually it's more like 2 seconds. Holding camera button for full two seconds is enough to start the app, but still there's additional 2 seconds lag, while camera application is starting ...and that's the real problem IMO.
gonta
Mon Aug 29, 2016 8:47 am
A little update - I couldn't edit my last post as they are moderated and it did't show up yet :(
There's a bug in firmware - camera app won't start with hardware shutter if it was active application and I have locked the screen. It will work only if camera app is closed or in background.
That problem applies only to shutter - C gesture works fine.
