Blackview BV2000, when you connect the charger or a usb cable, the body begins to vibrate, but there is a charge, but the computer does not see it. What could it be?
Tried different charging cables, still vibrates
 Maybe defect in the slot? There's the impression that when the cable is connected, the invisible hand presses the "return" button.
