Neill1
SPEAKER doesn't work...
Thu Aug 18, 2016 8:44 pm
Phone works ok, but only the LOUDspeaker works... no sound from the ear speaker... all settings seem correct...
Re: SPEAKER doesn't work...
Fri Aug 19, 2016 5:47 am
You mean the microphone works well , but the earphone has no sound ?
if yes, have you try this earphone on other device to check if it is problem about earphone ?
Best regards,
Admin
