Tonillovera
Camera does not work
Tue Aug 16, 2016 7:59 am
One week ago I bought a bv6000 by aliexpress, since then my camera is absolutely crazy, the firsts days did not open, there was a message like: it is not possible to connect with the camera.
I restarted the phone and cean the cache and then, the camera starts to work but all the photos were blurried, two days later the rear camera has dead it's not possible to connect and the lead one works 180° rotated, i explain it to aliexpress and they told me I have to upgrade my phone downloading a new Rom, but I have no idea what to do. Help me please
Re: Camera does not work
Wed Aug 17, 2016 9:16 am
what is the firmware version in your device now ?
Best regards,
Admin
Tonillovera
Thu Aug 25, 2016 7:57 am
Where I can find the firmware version?
Ajiw
Fri Mar 31, 2017 1:37 pm
Yeah, it's happened to me either, my rear camera can be accessed and the front camera is rolled back 180° such as on that picture
My bv build number is " bv6000_blackview_V01_20161216 "
shobaki_87
Sun Apr 16, 2017 8:34 am
I am using the phone as a calculator now
its a piece of shit !!
Tue Jun 13, 2017 7:57 pm
settings > about phone > update > (current version)
Dongermon
Tue Jun 13, 2017 8:03 pm
if you had problems why not seek support?
EDIT: i see that you did seek support, did you downgrade firmware and clean cache?
