Ouchta
A8 stuck in logo after the latest wireless update
Sat Aug 13, 2016 11:22 am
I tried to update my a8 yesterday, everything went well except in the update it said ERROR while updating.. i restarted the phone and the only thing i see now is Blackview logo in the screen for hours.
How do i fix this problem? is there any way to get off this issue? thanks.
Antoine
Re: A8 stuck in logo after the latest wireless update
Mon Sep 12, 2016 1:31 am
Same problem here
Phone frozen on the logo Blackview after last updated.
Аексей
Sat Apr 01, 2017 7:18 am
Такая же проблемма.ты нашел решения?
Blackmamba
Fri Apr 07, 2017 9:22 am
Try to hard reset the device: hold vol+ and power --> then recovery (here you will se dead andoid (no command) press power and vol + --> wipe data/factrory reset ----> yes/delete all user data. after than reboot the device and you are done!!!
Admin please explain us what cause this problem.
thank you in advance!
