Bl6000user
Bl6000 issues after last update
Mon Aug 09, 2021 5:56 pm
Hi, I am experiencing some issues after the last update... The light sensor is playing up.
The phone is on standby, I press the power to wake up, I can see the pattern unlock screen fine, I unlock the screen and the brightness drops to 0%, I have to then try and pull the settings shade and manually turn the brightness up.
This tends to happen most when it is sunny.
I disabled the auto brightness in settings, but the setting will revert back to on after a while.
I am unable to use the phone unless I am holding it. If the phone is on the table and I just swipe at it my swipes are not interpreted correctly, if I touch the side of the phone then its fine. I remove my finger from the side of the phone and problems again.
The phone has not been dropped, not been damaged and has not got wet.
elfelicien
Re: Bl6000 issues after last update
Fri Sep 24, 2021 4:01 pm
I had the same one time and after a reboot it seems to be ok.
