jungletrekker69
Microphone DOES NOT work!
Thu Aug 04, 2016 3:08 pm
I have received the phone and have not used the phone in the rain or dropped it. Everything is OK except the microphone DOES NOT work when I record movies or when I switch off the sound recorder.
Playing music isnt a problem though the speaker quality is bad for a good looking rugged phone ...
So tell me Mr Administrator - what is wrong withg the microphone not working???
Re: Microphone DOES NOT work!
Fri Aug 05, 2016 7:14 am
the microphone do not have sounds or sound is not clear?
when you record movie or switch off the sounder record, if you have ever check the setting option ?
Best regards,
Admin
