mauriziomomix
Radio problems (BT and WiFi)
Sun Jul 11, 2021 4:25 pm
Hello, I just bought the BL6000pro and I see it seems to have good materials and excellent features but I found some connection problems with WiFi and huge problems with Bluetooth.
WiFi: the connection seems to be sometimes sleeping, actually several notifications are coming all together (like being reconnected). And the same has happened using a multiplayer game, when the connection has been stopped and I lost the match.
Bluetooth: the pairing with the car free-hand falls and rises every 3 or 4 seconds. Continuously! So the connection is unusable.
Obviously, the same connections are correctly working with other smartphones.
The device has been updated with all ROM upgrades available (Android 11 and BL6000Pro_EEA_S1000A_V1.0_20210516V04).
Is there any update or known solution for this type of problem?
Thanks in advance
Maurizio
picooloo
Re: Radio problems (BT and WiFi)
Tue Aug 17, 2021 11:15 am
I have the same problem...
picooloo
Fri Sep 03, 2021 4:05 pm
I have same problem...I have a message, bluetooth stop running, and bluetooth reboot....
I can't use bluetooth in m'y car :-(
Ringberg
Fri Oct 08, 2021 7:29 am
Same problem here, BV 5100. Wifi looses connection.
Kochevnik_Pol
Tue Dec 21, 2021 9:02 am
All the same. There is no normal connection. Please fix this problem.
After installing the new firmware, the smartphone immediately connected to the car and was no longer disconnected. Many thanks to the developers, they restored a very necessary function for me. Well done.
