peterOnDroid
BL6000 Pro hotsport connected no internet
Mon May 24, 2021 8:58 pm
I cannot get my hotspot to share my phone data. When a devices tries to connect I get a "connected no internet" . If I take the sim card out and put it in my old samsung galaxy, the devices connects and get the internet.
I am regretting buying this phone -- it seems many things just do not work properly -- or a big thing like being told that fixing a faulty finger print sensor is the user's responisibly ("we will mail you the replacement part at not charge, here are two youtube videos to see how it is done")
Re: BL6000 Pro hotsport connected no internet
Tue May 25, 2021 8:05 am
Hello, sorry to make this inconvenience caused to you. May I know which card did you use? Where are you from? Can you provide the version number for me?
peterOnDroid
Tue May 25, 2021 1:19 pm
I am in Canada, use Rogers 4g network (the BL6000pro does not work on their network).
When i move the sim card to my old samsung there are no problems setting up and connecting to the hotspot so not an issue with sim card/rogers
peterOnDroid
Wed May 26, 2021 2:58 pm
The APN is not changable. It is set by the carrier (rogers).
May have been a misunderstanding in my last post. I can connect to rogers 4g/lte network, but i cannot connect to thr 5g network; the bl6000pro 5g bands not compatible
Once again the issue is tethering from the bl6000 pro. Putting the sim into another phone i can tether
Thu May 27, 2021 9:09 am
Hello, if you can change this ANP, then you can't use it. Please contact the seller where you bought this phone.
Users browsing this forum: Google [Bot] and 1 guest
