bektorkhan
BV6300 Pro Bluetooth Audio studder!!
Wed May 19, 2021 12:42 pm
After 8 seconds bluetooth audio starts to studder, tested sveral audio sinks. All studder.
Otherwise BT works better than BV9500 Pro for watches and other medical equipment. Does not need BT reset to work.
But unusable to stream music...
Just waiting for it to go into the Security loop lockdown, after another factory reset... though.
Great phone otherwise, great LTE coverage and GPS. Better than my bv9500 Pro that got broke after three months, camera glass shattered.
Luckily BV6300 Pro has Camera protection glass available on the market!
Would be nice  if you can fix these issues!
And please make a topic for BV6300 Pro and BV6300
Best Regards
/Mikael
Re: BV6300 Pro Bluetooth Audio studder!!
Thu May 20, 2021 6:17 am
Best Regards
/Mikael
Good day, Mikael. First, I would like to know the BV9500 can work still yet?About your suggestions, I will feedback to our engineer.
Neville
Thu May 20, 2021 12:13 pm
Best Regards
/Mikael
Have you tried turning on Developer Mode and changing to a Bluetooth codec supported by your audio equipment?
bektorkhan
Fri May 21, 2021 6:07 pm
Best Regards
/Mikael
Yes my BV9500 Pro stll works, but not watertight anymore, and the main camera optics are crap, since the crack is in front of it. I needed a working camera.
bektorkhan
Re: BV6300 Pro Bluetooth Audio studder!! Fixed!
Thu Jun 03, 2021 9:51 am
After the second factory reset everything is working perfect... A very good phone.
Good LTE coverage, GPS , Cam is OK .. for the Price its awesome!!
Only minus found is the Wireless Charge position is offset 10 mm down, does not fit WC car/MC holders without fixing.
My third Blackview... tried others, but nothings like Blackview.
/Mikael
