Issa87
Anyone have issue with BL6000? Is it not Waterproof?!
Fri May 07, 2021 7:52 pm
I bought BL6000pro, i just received it after 5 month waiting for black color ,I used it exactly for 3 days before it stopped working.
There was few some manufacturing mistake or issue , I think there was an issue with the camera, as the quality was bad, I compared it with few other phones and with other blackview phone as well , my camera for some reason wasn't that good.
the phone is not working and that's due water came into the phone, I understood the phone is waterproof (water was not more than 10cm covering the phone for less than 30 sec)
The phone screen went blinking and off and out, I thing they forgot seal the phone while manufacturing, anyone having or had issues with BL6000pro like me?
Note : I still waiting for reply from support team regarding what they will do about it
After water went in
Screen after water went in
Re: Anyone have issue with BL6000? Is it not Waterproof?!
Thu May 13, 2021 7:17 am
1. May I know what is the exact problem with the camera? Or can you shoot the pic for us to check?
2. Did you put the smartphone into the water? That is why the camera is not working anymore???
Neville
Fri May 14, 2021 12:39 am
They put the smartphone into the water because Blackview told them it was waterproof...
Users browsing this forum: TimothyLal and 1 guest
