Tramper
BV9800 Pro locks up
Thu May 06, 2021 11:03 pm
My BV9800 Pro will randomly lock up, usually happens when texting but don't know if that's what causes the problem. I tap the on/off button it works fine again..for awhile
Tramper
Re: BV9800 Pro locks up
Fri May 07, 2021 8:01 am
Can you restart to check? If it still can't work, you have to restore the factory settings.
