YTC1
BV6300 Pro
Thu May 06, 2021 8:34 am
Sorry, can't seem to post to the B6300 pro forum.
I am considering buying a BV6300 and I have a query about what apps are pre-installed on the BV6300pro.
I like a phone to be as near stock as possible, but amongst the apps I do not like very much are FaceBook, twitter and other social media apps.
Does anyone know what apps are installed on the BV6300pro please?
Re: BV6300 Pro
Fri May 07, 2021 8:10 am
Hello, you can install the App you like or you can delete the App you don't want
YTC1
Re: BV6300 Pro
Fri May 07, 2021 2:06 pm
Thanks for the reply, but I just want to make sure that FaceBook (especially) is not pre-installed. When it is pre-installed, then on every phone I have ever had you cannot uninstall it and it keeps getting updated (even though not using it).
Is there a list of installed apps? Or is is it stock android, with not bloatware?
TIA
Re: BV6300 Pro
Thu May 13, 2021 7:28 am
TIA
Hello, that wouldn't happen in our smartphone.
Brate184
Re: BV6300 Pro
Sun May 16, 2021 2:05 am
Hello, I just bought the 6300 pro a week ago and it does not come wth Facebook or Facebook apps. Comes with standard Google apps only. Hope it helps.
