IIStalkerII
BV9900 Pro Battery Sudden Drop
Wed Apr 28, 2021 3:31 pm
Im having a very serious issue over here, my Blackview Bv9900 Pro is suddenly dropping from 70-80% to 0%, my cellphone is almost new it doesn´t have more than 4-5 months of life, and it´s already turning off and having battery problems, i´m using the induction charger only.
I´ve tried turning on and off, clearing cache and still doesnt works, its kind of infuriating that an almost new cellphone is becoming unusable, my battery wont last more than an hour or two, any advice to fix this issue would be greatly appreciated.
Re: BV9900 Pro Battery Sudden Drop
Fri Apr 30, 2021 7:51 am
Hello, after checking with engineer, it has to be repaired and could you please contact the seller directly? Or please contact the after-sales department directly: support02@blackview.hk
