Glyderworm
BV9900 Pro DP Alt mode
Sat Apr 24, 2021 8:02 am
I wanna know if the BV9900Pro supports HDMI over usb-c.
i read that you need DP Alt mode for that.
Is BV9900Pro capable of video output through usb-c?
Re: BV9900 Pro DP Alt mode
Sun Apr 25, 2021 8:15 am
Glyderworm wrote:
Hello, it can't be supported.
Glyderworm
Wed Apr 28, 2021 8:36 am
blackview_admin wrote:
Glyderworm wrote:
thx for the quick answer, how about MHL. is it possible to mirror you screen with an mhl adapter usb-c to hdmi?
Fri Apr 30, 2021 8:06 am
Glyderworm wrote:
This is not supported, you can only use the projection method
