manu-lyon
BV4900Pro : unable to keep backgrounds app alive
Mon Apr 19, 2021 8:50 am
First, I'm sorry for my bad english.
I own a BV4900pro since 6 month.
Android is up to date.
Since the begining, I'm unable to keep my apps working in background. I set to OFF the battery manager for theses apps, but after a few hours, theses apps are not running.
Facebook, Messenger, Outlook, Ebay... i'm unable to keep one app alive all day long. And i miss very important notification.
I searched in all settings menus, nothing about that.
Thanks !
Re: BV4900Pro : unable to keep backgrounds app alive
Tue Apr 20, 2021 7:03 am
manu-lyon wrote:
Thanks !
This menu interface is often used in the standby interface to select the whitelist and go to the settings to add duraspeed to the whitelist.
manu-lyon
Sat Apr 24, 2021 3:01 pm
i kow how to access to the white list menu, but there is no 'duraspeed' in the list.
should i install duraspeed first ?
Sun Apr 25, 2021 8:01 am
Hello, you can search for it in the Setting, you can enter the "Durasppeed" name to search directly.
