zkore
BV6300 Pro - i Need ROM (Global)
Fri Apr 09, 2021 4:24 pm
Please! i need the rom for modelo BV6300 Pro.
I downloaded a version but the applications are with Russian language and it does not work for me!
alyniat
Re: BV6300 Pro - i Need ROM (Global)
Sun Apr 11, 2021 12:28 pm
Great one thanks for sharing such a valuable post ..
tcpdumb
Fri Apr 23, 2021 9:49 am
Howdy people,
is it possible to have a OTG Firmware bundle? My BV6300 Pro arrived yesterday, made tons of updates and the only thing left working is sideload. About the same thing happening to my A80 Pro once :-(
Sun Apr 25, 2021 8:50 am
tcpdumb wrote:
Howdy people,
Did you download the software to update it?
What language to set up it?  Can you provide the language for us to verify it?
tcpdumb
Mon Apr 26, 2021 7:32 am
Good morning,
this has been some OTA-Update. Language was german (Europe). I have been downloading BV6300Pro_EEA_TE988_V1.0_20200909V15.zip extracting to TE988_DK_DK018_71_Q0_V2.3.7.3_20200909 to fix it but had no success.
July 13th 2020, I've had some very nice chat with support02 helping me out, when my A80 Pro had the same issues.
Mon Apr 26, 2021 7:49 am
tcpdumb wrote:
Good morning,
Hello, please contact the after-sale department directly, I sent your question to them, here is the email: support02@blackview.hk
Jose.t
Tue May 18, 2021 6:12 pm
Hola, mi bv6300pro tiene la ROM v14, veo que la stock es la v15, ¿es posible que me manden actualización vía OTA?
Mi teléfono tiene fallos de forma aleatoria con el panel táctil tal y como describe otro usuario con el teléfono bv9500. ¿Es posible que se solucione con actualización?
Hello, my bv6300pro has ROM v14, I see that the stock is v15, is it possible to send me an update via OTA?
My phone is randomly crashing with the touchpad as described by another user with the bv9500 phone. Is it possible that it will be solved with an update?
Thu May 20, 2021 6:43 am
Hello, now there is not updating the plan of BV6300PRO.
Jose.t
Thu May 20, 2021 2:26 pm
Rom installed in my bv6300pro :BV6300Pro_EEA_TE988_V1.0_20200708V14
Rom stock or latest version:BV6300Pro_EEA_TE988_V1.0_20200909V15
Can i update via OTA?
Can I download and update from SD card without risk? Can something go wrong?
What are the differences between the two roms?
Fri May 21, 2021 3:00 am
Hello, this is not any difference.
Users browsing this forum: BryceWah, DarrelShorb, Gregorymes, RupertLiela and 3 guests
