adrianchansp
9800 Pro - No earpiece or bluetooth earpiece detect
Wed Apr 07, 2021 5:22 pm
Hi Blackview Support,
I bought the hp from your kickstarter campaign :)
I was watching videos using Blackview 9800 Pro with normal earpiece and I dropped the phone. The hp shutdown instead of remained on.
I restarted the hp and only the speaker is working. I tried to connect different earpiece and also pair with bluetooth earpiece (last time it worked).
However no earpiece is able to be detected as connected. I bought a USB C to 3.5mm connector to test as well but no wired earpiece is detected still.
Only the speaker is functioning ok.
Thanks
Re: 9800 Pro - No earpiece or bluetooth earpiece detect
Thu Apr 08, 2021 2:45 am
Thanks
Will there be a headset icon when the headset is plugged in under check|?
adrianchansp
Thu Apr 08, 2021 2:56 pm
Hi support,
No headset icon when plugged.
Fri Apr 09, 2021 6:49 am
adrianchansp wrote:
Hi support,
No icon means that the headset is not recognized.
adrianchansp
Tue Apr 13, 2021 3:54 pm
Before dropping was recognized and in use. Now after dropping cannot recognize.
What it means then?
Wed Apr 14, 2021 6:46 am
adrianchansp wrote:
What it means then?
So they are not being connected.
adrianchansp
Wed Apr 14, 2021 9:59 am
How to resolve it?
Thu Apr 15, 2021 3:18 am
adrianchansp wrote:
How to resolve it?
They may not be compatible with each other, does rebooting help?
