Demianstrouble
BV 9800 Pro can't make, receive calls, or go on google play, when my wifi is active.
Tue Apr 06, 2021 11:09 am
I have BV 9800 Pro and can't make, receive calls, or go on google play, or google search, when wifi is active.
It also loses gps signal as soon as I start driving and doesn't gain again until I step out of vehicle and restart maps, which makes the phone absolutely useless to me, for I need navigation for my work.
I've tried update, reset, uninstall and reinstall, gps repair tools...nothing works. Help!!!!!
Re: BV 9800 Pro can't make, receive calls, or go on google play, when my wifi is active.
Wed Apr 07, 2021 3:26 am
Press *#87#, open the GPS in the open area to search for the star value, to see how the GPS signal.
