Alexandru I
BV9700 Pro charging cable compatibility with BV8000Pro
Thu Mar 25, 2021 10:32 am
Does anybody know if the type C charging cable for BV9700 will also work with BV8000? It seems to be very similar.
I'm asking because my BV8000 Pro cable no longer charges properly and it's very hard to find a new Extended Type C cable that ships in a couple of days...
The only local store similar cable I found is one for BV9700.
Thanks!
Re: BV9700 Pro charging cable compatibility with BV8000Pro
Sat Mar 27, 2021 6:06 am
Alexandru I wrote:
Thanks!
This charging cable is relatively long and can only be charged with the data cable of BV9700Pro
