bunjatec
BV9800 Updates and memory issues
Mon Mar 22, 2021 9:52 pm
 I have a BV9800 and I noticed the latest security patch was in 05/08/2019 firmware build is  BV9800_EEA_S65_V1.0_20191016V10 .
Is there a newer version coming anytime soon or does blackview not update it's products?
Also this has been sent back for repair once already due to a memory issue causing plications to crash all the time, it's returned and still doing the same thing.
I ran a test report and got the following :
Results summary
[table][tr][td]Test[/td]
[td]Operations[/td]
[td]Result[/td]
[/tr]
[tr][td]CPU[/td]
[td]22.9 billion[/td]
[td]OK[/td]
[/tr]
[tr][td]Memory[/td]
[td]290.5 million[/td]
[td]NOK[/td]
[/tr]
[tr][td]Data verification error[/td]
[/tr]
[tr][td]Storage[/td]
[td]5.1 billion[/td]
[td]NOK[/td]
[/tr]
[/tr]
[tr][td]Battery stress[/td]
[td][/td]
[td]OK[/td]
[/tr]
[/table]
Result: device NOK
Test software
[table][tr][td]Product[/td]
[td]Phone Check and Test v13.2[/td]
[/tr]
[tr][td][/td]
[td]inPocket Software[/td]
[/tr]
[tr][td][/td]
[td]www.inpocketsoftware.com[/td]
[/tr]
[tr][td]Report date[/td]
[td]22 Mar 2021 21:29:28[/td]
[/tr]
[/table]
Device information
Device
[table][tr][td]Model[/td]
[td]A-gold BV9800[/td]
[/tr]
[tr][td]Brand[/td]
[td]Blackview[/td]
[/tr]
[td]BV9800_EEA[/td]
[/tr]
[tr][td]Serial#[/td]
[td]BV9800EEA0005583[/td]
[/tr]
[/table]
Operating system
[table][tr][td]Android[/td]
[td]9 (Pie)[/td]
[/tr]
[tr][td]API level[/td]
[td]28[/td]
[/tr]
[tr][td]Security patch level[/td]
[td]2019-08-05[/td]
[/tr]
[tr][td]System uptime[/td]
[td]2 hours, 03:56[/td]
[/tr]
[tr][td]Root access[/td]
[td]Not detected[/td]
[/tr]
[tr][td]Build[/td]
[td]BV9800_EEA_S65_V1.
0_20191016V10
[/td]
[/tr]
[tr][td]OpenGL ES[/td]
[td]3.2[/td]
[/tr]
[tr][td]Java VM[/td]
[td]2.1.0[/td]
[/tr]
[tr][td]Architecture[/td]
[td]aarch64[/td]
[/tr]
[tr][td]32 or 64-bit[/td]
[td]64-bit ARM[/td]
[/tr]
[tr][td]Kernel version[/td]
[td]4.4.146
[/td]
[/tr]
[/table]
Users browsing this forum: Buddyulced, TimothyLal and 4 guests
