Would be great if someone knows a solution.
Thank!
											MrRage wrote:I also have the same problem. Where can I find the version number or is it the one that says current:
A60Pro_EEAM169_V1.0_20210308V20_20210309-0451
											conrad1on wrote:Device: A60Pro
Android version: 9
Build number: A60Pro_EEA_M169_V1.0_20210308V20_20210309-0451
I believe that I'm having the same issue. Ever since the recent software update, high-definition videos have been very laggy. I am able to play videos via a browser on the phone, but only in a resolution no more than 240p. Any higher, and the video struggles to keep up with the audio. Using the YouTube app though, even videos in the lowest resolution will lag.
I don't know if this is relevant, but since the previous software update a few months ago, I started getting a lot more notifications that would pop up at the top of my screen which would hang around for a few seconds before disappearing. These seem to be from apps that predominantly deal with media files, and it was as if they were constantly scanning for new content multiple times a day. I don't know if this behaviour is normal, but it's very distracting to have your phone beside you and see it happening all day long, to the extent that I actually uninstalled a number of apps just so that I wasn't seeing it so often. But like I say, this may have nothing to do with the current problem with lagging video.
											conrad1on wrote:Just to be clear, the issue I'm having is with playing video, namely from YouTube etc. Though from what I can tell, videos recorded using the phone's camera seem to play back more or less smoothly on the device itself.
blackview_admin wrote:conrad1on wrote:Just to be clear, the issue I'm having is with playing video, namely from YouTube etc. Though from what I can tell, videos recorded using the phone's camera seem to play back more or less smoothly on the device itself.
Yes, that is why we would like you to record the video for us to check.
blackview_admin wrote:Sinett wrote:Hello, i had a software upgrade a few days ago and since then i have video issues. It´s like the fps ist very low and it is kinda "lagging" the sound continues normally. Apps like youtube and 9gag, which i use a lot on my phone are barely useable. I would like to solve this problem without resetting my phone if possible.
Thank!
Hello, please provide your version number for us to verify it.
