gabrielgubb
Bv6100 headphones not working
Tue Mar 09, 2021 5:02 pm
Hello.
On my BV6100 the 3.5m Jack connector doesn't work. I try to plug my headphones but the cable still won't go in.
Is there any way to do it or it's faulty?
I know this phone is ip68 protected but this means you cannot use headphones?
Thank
Re: Bv6100 headphones not working
Wed Mar 10, 2021 9:27 am
gabrielgubb wrote:
Hello.
Thank
Apple gray, TYPE-C plug (exposed 7.0MM), OD4.0*1000MM, core 17/0.16*2C OPP packing
gabrielgubb
Wed Mar 10, 2021 9:51 am
Thank you. But this means standard headphones aren't supported?
Thu Mar 11, 2021 3:23 am
yes
