mihaelj
Screen proximity sensor calibration?
Fri Feb 26, 2021 9:41 am
I need help with my 9900 Pro screen staying turned off during calls. I routinely break calls by touching screen with my face. My previous cell phone from another vendor had no issues with this.
My 9900 PRO has the proximity sensor calibrated to around 2 cm or cca 1 inch.I would like to increase this value to at least 5-10 cms as I can't always press the cellphone to my head during call.
Is there a way to change this value? I did try to go through the procedures described in the following thread but I don't see that option. I have P-sensor button but this is only where I can see at which distance it reacts to. I can't change the value. There is also a button Smart PA calibration but I am not sure if this is related.
Please advise. Thanks!
Re: Screen proximity sensor calibration?
Tue Mar 02, 2021 8:26 am
Hello, This can't be changed, you have to get closer with your ears.
Tue Mar 02, 2021 8:27 am
