laurent78610
Are BV9900PRO wifi calls enabled under android 10
Fri Jan 29, 2021 1:39 pm
It sounds accordingly to BV support that Wifi calls for BV9900PRO running android 10 is not  available and that I have to flash the phone to android 9.
Is this right ? strange
Joedafone
Re: Are BV9900PRO wifi calls enabled under android 10
Mon Feb 01, 2021 4:46 am
Does this apply to ALL Android 10 users on the BV9990Pro?
I updated to Android 10 but I can still see the VoLTE icon on the notification bar - does that mean that WiFi calls are working in my case?
Thanks,
Joe
Mon Feb 01, 2021 8:26 am
Thanks,
Joe
Hello,  Android 10, It doesn't have this function anymore.
Otti
Tue Feb 02, 2021 9:43 am
On my BV6300 with Android 10 the WiFi Call option still exists (also see Google Android help center Wi-Fi Calls). But it also says that the option is not visible when the mobile provider does not support the feature.
You can find the setting under Network & Internet -> Mobile Network -> Extended Settings, too.
And sometimes a reboot of the mobile device helps to get the WiFi-Call connection back running,.
