juandi34
Blackview BV9600E Android 11 - LiR v313 perfect ROM !!!
Thu Jan 28, 2021 6:43 pm
Please, team:
I know that you will not update this model to Android 10, but I have a question:
When may be a little flash update to have led notification colors unlocked ???
....BV9700 Pro has it unlocked. Also, I flashed BV9600E on Lineage 17 and I can have it unlocked and can use LED notifications colours manager aplications.
Can you update this little error ???
Thank you.
BV9600E User
juandi34
Re: Blackview BV9600E update needed (android 10 and 11)
Fri Apr 16, 2021 9:02 am
On this russian forum, you can find updates.
Updating, you can solve NOTIFICATION LED COLOUR SELECT, and many things ...
Link:  https://4pda.ru/forum/index.php?showtop ... y105609310
Blackview official team: THANKS FOR DOESNT UPDATE THIS GREAT PHONE.  :(
BV9600E User
juandi34
Mon May 17, 2021 10:38 am
A user has been tested a ROM file and post the best one  ....  https://4pda.to/forum/index.php?showtop ... y106728934
The ROM file is: https://github.com/phhusson/treble_expe ... pps.img.xz
Good luck to anyone who try it.
BV9600E User
juandi34
Re: Blackview BV9600E update needed - (FOUNDED)
Tue Jun 15, 2021 7:54 am
Also, you can flash BLISS ROM 14.2 using Android 11.
I have flash it, and runs perfectly. Very fast, and no hardware problems.
Only the camera app is very poor, but you can install another one.
The LED notifications app (I try using 3 app), also runs perfect, and can use RED, GREEN and BLUE colours on phone LED to alert anything.
System location (GPS) runs very fast, and exactly.
NFC also runs OK
Bluetooth runs also very fine.
... on this ROM, you can root phone whatever you want using Magisk.
Good luck.
BV9600E User
juandi34
Re: Blackview BV9600E Android 11 - 100% TESTED
Thu Jul 29, 2021 8:21 am
There is another Android 11 AOSP firmware that runs PERFECT, stable, and right on my BV9600E.
It is CAOS 11 (The official firmware forum site: https://forum.xda-developers.com/t/offi ... 1.4265059/ )
Also, there is another Android 11 proyect from the same creator. It is LiR (forum link: https://forum.xda-developers.com/t/unof ... r.4237683/ ) which is very similar to CAOS 11, and you can change flash updates between them.
You must decide: CAOS or LiR  !!!!
I give you 2 links to proceed to update to CAOS (is all that you must need to update it):
1 - The updated drivers and instructions how to flash via TWRP BV9600E : https://www.getdroidtips.com/aosp-andro ... iew-BV9600
2 - The file to flash CAOS-Android 11 on this BV9600E device via TWRP : https://sourceforge.net/projects/treblerom/files/CAOS11/2021.08.15/caos-v312-210815-arm64-bgZ.img.xz/download?use_mirror=netix
Good luck, and remember: there are 2 proyects ... CAOS and LiR
Bye.
BV9600E User
juandi34
Re: Blackview BV9600E Android 11 - Updated: 2 ROMs options to update
Tue Sep 14, 2021 10:35 am
UPDATE:
New update of Lineage LiR ROM (v313) with SafetyNet and NFC payment running OK.
Magisk works fine (green SafetyNet),  !!!!!!!!! ;) :D
https://www.htcmania.com/showpost.php?p ... stcount=37
All other BV9600E functions working properly, and very quickly.
Wellcome to Android 11 !!!!!!! :D
BV9600E User
