snowy
Bv9700 PRO _ TEE key GOOGLE red mark issue
Sun Jan 24, 2021 4:38 pm
After bricking my phone i successfully flashed a custom stock firmware but I have been stuck with the GOOGLE key and TEE key red mark on the menu for ages, i can't find the way to get rid of it. I have flashed with different custom rom with sp flash tool and recovered the IMEI.
- BV9700Pro_S1_190806 (in use)
- 2019071217_s41v71c2k_jk_eea.
Both of them works fine but im still stuck with the red water mark on the corner.
I tried to do the method with "adb pm uninstall --user 0 com.mediatek.factorymode" and "adb shell pm uninstall -k --user 0 com.mediatek.factorymode" none of those work.
 anyone could help, im lost.
snowy
Re: Bv9700 PRO _ TEE key GOOGLE red mark issue
Wed Jan 27, 2021 7:13 pm
Thank you for your reply, i contacted them but still havent got any reply yet.
joe tigercat
Sun Feb 07, 2021 1:44 pm
Red letters in the top right corner? I believe this is fixed by unlocking your bootloader
snowy
Thu Feb 18, 2021 1:01 pm
Is there any solution ? It has been a month that i did not get any answer from the mail you provided, and my last post has not been published.
Im starting regretting to have spent my money on this phone.
_-MrGood-_
Sun Feb 21, 2021 2:42 pm
Hello, I checked with our colleague and we didn't receive an email from you, can you send it again?
im also experiencing this issue
snowy
Sun Apr 11, 2021 3:30 pm
Could you send me the support mail address of blackview to fix this problem ? I would really appreciate.
Mon Apr 12, 2021 4:03 am
This is the email: support02@blackview.hk
