PiranhaPete
BV6000S side panel screw type and size
Mon Jan 18, 2021 6:08 am
I have a BV6000S and want to change the battery. The screw tool supplied with the phone (see attached file) does not fit the side panel screws.  I have read that it requires a torx T5, but this does not appear to be the case. The screw looks like it requires an alan key about 1mm. Please advise the correct screw type and size and where I can get one?
BV6000S screw.jpg (4.11 KiB) Viewed 3189 times
