kardo7
proximity sensor
Sat Jan 16, 2021 10:54 pm
Hello i have bought a bv9900E and every time i make a call the screen does not go off. its any problem with the proximity sensor or it does not have one?
thanks
Mentat
Re: proximity sensor
Wed Mar 24, 2021 1:22 pm
Hi! I have the same issue. The proximity sensor not works on my new BV9900E. Can i calibrate this sensor?
legoprof
Fri Mar 26, 2021 8:19 am
 My Proximity sensor does not work. I tried to calibrate with the single test but the test always fails. I don*t have a screen protection. What can I do? My Phone 9800pro is one year old.
Sat Mar 27, 2021 6:08 am
Dial interface input *#87# to calibrate the distance sensor.
