Mjolinor
NFC is weak.
Wed Jan 13, 2021 12:11 pm
I have been using a BV6000 for ever to measure my blood sugar via NFC. On the BV6000 the sensor can be up to 40mm away from the phone and anywhere withing 30 mm of the centre of the back.
I recently got a BV8000 to replace it with and the NFC range is terrible. It has to be exactly in one particular location just above centre and within 10 mm of the back to work. Is there any way to make the NFC more sensitive?
The current OS is: v0.1_20170803_20180307-1950
I cannot change the OS either up or down using manual update and OTA updates are current.
AERO
Re: NFC is weak.
Tue Jan 19, 2021 8:48 am
Do you know where is exactly your NFC?
Mjolinor
Re: NFC is weak.
Tue Jan 19, 2021 8:55 am
Yes.
AERO
Re: NFC is weak.
Tue Jan 19, 2021 9:17 am
Mjolinor wrote:
Yes.
Usually NFC has only very little action range around the TAG.
Mjolinor
Re: NFC is weak.
Tue Jan 19, 2021 12:20 pm
I know the range is small, it uses the near field. It is designed to be that way but this phone is way out of spec at 10 mm.
