NPhilipson
BV5100 Pro needs a wedge app
Mon Dec 28, 2020 7:47 am
I could not find any forum for this device (BV5100 Pro). Unfortunately the scanner on this phone is of limited use as there seems to be no way of putting scanned data directly into our own apps. On other devices of this type it is done with a "wedge" app which sits in the background an inputs any scanned data into the app running in the foreground. If anyone knows of a way this can be done I would would be very grateful.
It is a shame because this phone is very promising and I would love to be able to use it for work. Maybe Honeywell's solution could be adapted to this device since it uses a Honeywell scan engine.
Re: BV5100 Pro needs a wedge app
Tue Dec 29, 2020 6:30 am
This description needs to be customized, currently this can only describe
Neville
Wed Dec 30, 2020 2:05 am
We are not asking Blackview what it currently does...we are TELLING Blackview to urgently fix firmware so this device (aimed at logistics companies) works as it should...otherwise Blackview has wasted its time and the phone won't sell. We have clients interested in ordering several hundred units, but only if the scanner can feed data to other apps they use.
It is the difference between a tool and a toy.
Wed Dec 30, 2020 6:52 am
At present, we can only save the scanned two-dimensional code and bar code to our mobile phone, and cannot operate other ones. I have feedback your suggestion to our engineer.
jankon
Thu Jan 28, 2021 8:02 am
We have same problem. We have Unitech device with same bar code sensor and it works fine.
PickApp
Tue Feb 16, 2021 10:11 am
We are also waiting for this issue to be resolved.
We've tried (nothing worked):
  1. Listening for broadcast events.
  2. Integrating the Honeywell SDK.
  3. Running Honeywell sample Apps.
It seems that the device is blocking the scan data broadcast.
alangiu
Tue Mar 02, 2021 10:52 pm
We' re having the same problem. Did you find a solution to make the barcode scanner work?
Wed Mar 03, 2021 3:32 am
[*]Listening for broadcast events.----what is the problem of broadcast?
[*]Integrating the Honeywell SDK.----- could you describe the problem?
[*]Running Honeywell sample Apps.------It can't be used in App
Wed Mar 03, 2021 3:33 am
Hello, what is the problem of the barcode scanner work?
alangiu
Thu Mar 04, 2021 8:06 am
The problem is that a device with a barcode scanner should read the barcode in every field of any application. It should work just as the keyboard works. When I read a barcode it should "write" it just like a keyboard.
[Example - Use case]
1. I'm writing a text message to somebody;
2. I want to send him the barcode of the product I have in front;
3. I scan the barcode (978020137962);
4. The barcode is written directly into the message;
The same should happens for every application I'm using. This would really allow to use your phone for logistics purposes.
Every device with Android and a barcode scanner works like this.
Users browsing this forum: BryceWah, Dannypap, JimmyHom, JohnnyBrine and 3 guests
