rortas
BV9100. Touch screen randomly not working. Locking the device and waking up again makes the touch screen working again.
Sun Dec 27, 2020 9:58 pm
I'm a proud owner of a blackview BV9100, bought a year ago on Blackview's Aliexpress official store.
A weird problem arised some weeks ago. Sometimes the touch screen stops working. The only way to get it to work again is using the lock button to lock device and wake up it again. Then the touch screen works again perfectly.
Tried to reboot the device. Uninstalling the lasts apps installed. Erasing the cache of all apps. Changing the defauld android launcher by novalauncher.
It is absolutely random. It can happen twice in a minute, or one time in a day. Please, Have any of you heard something similar to that? Is there anything I can check? Any advice would be very appreciated.
Thank you very much for your attention.
Sorry if I posted on the wrong board. I can not find a board for BV9100 only.
Re: BV9100. Touch screen randomly not working. Locking the device and waking up again makes the touch screen working aga
Mon Dec 28, 2020 6:44 am
rortas wrote:
Could you please help us capture one "Log" for us to check the problem?
redbullnik07
Mon Dec 28, 2020 9:40 pm
Hi, I have the same problem with Blackview BV5900.
rortas
Mon Dec 28, 2020 10:28 pm
Hello. I will try to catch a log when the touch screen stops working. It is absolutely random, so it will be a bit difficult for me to reproduce the issue while conected to the computer and get the log with adb.
Thank you so much for your attention.
Tue Dec 29, 2020 4:25 am
Hello, what the same problem with BV5900? Could you please describe it clearly?
Tue Dec 29, 2020 4:28 am
Hello, please send an email to me, I will send the instruction for you to follow the steps, here is my email: mary@blackview.hk.
redbullnik07
Tue Dec 29, 2020 8:32 am
https://streamable.com/vbbmet
https://streamable.com/3vvnvg
Wed Dec 30, 2020 7:21 am
Restore the factory settings under verification, if it does not work. The screen is broken. Please let me know when you tested it.
Wed Dec 30, 2020 7:22 am
Restore the factory settings under verification, if it does not work. The screen is broken. Please let me know when you tested it,
redbullnik07
Wed Dec 30, 2020 4:12 pm
I reset the phone from the factory, but the lock appears again (filming is from the 2nd lock, after the first reset)
