frchassot
BV6300 PRO NFC issue
Wed Dec 23, 2020 11:59 am
I have before a BV5800 pro and no problem to scan a nfc tag. There is few times, i change for a BV6300 pro, and now I can't scan the same nfc tag.
Thanks you for your help.
Re: BV6300 PRO NFC issue
Thu Dec 24, 2020 6:38 am
frchassot wrote:
When you scanned, do you put it in the right place?
frchassot
Fri Dec 25, 2020 10:03 am
Yes, I try to scan with an other device and it works.
Sat Dec 26, 2020 3:31 am
Can you use a wireless charger to charge it? The position is different with NFC. :D
frchassot
Sun Dec 27, 2020 5:10 pm
Can you tell me the position to the nfc on the phone?
