batonga
A80 pro Stock ROM (Android 10)
Sat Dec 19, 2020 1:19 am
I recently bought an A80 pro on Amazon (DE) and got one with Android 10 preinstalled.
Because I like LineageOS I tried to flash a GSI ROM, but ended up in a bootloop. So I tried to flash the Stock ROM with SP flash tools for the A80 pro with Android 9.0, but got only static noise on screen after flashing. Then I realized, that I got a new Version of the A80 pro (with Android 10 preinstalled). Are there any changes on this devices to improve integrity (like any implementation of verfified booting)? Luckily I found a russian Stock ROM for the new device with Android 10, but I would prefer the global/eu version of the Stock ROM. Is there any download link?
Re: A80 pro Stock ROM (Android 10)
Sat Dec 19, 2020 8:08 am
batonga wrote:
https://mega.nz/file/HbpTQSbT#a-N4QTxDM ... 6IHqfZ4hHc
https://mega.nz/file/GO4Sjajb#jQrnATVl5 ... Trf_e1tE2Q
Goolshash9
Sun Dec 20, 2020 11:15 am
hi, i bought a phone A80 pro. Tried updating it to android 10. Everything worked well on firmware version 05. I tried version 07, which was posted here. But on it, when the bluetooth headset is connected, the interface starts to freeze. When the connection to the headset is disconnected, the freezes stop, and even if you leave the bluetooth on at the phone. I returned to firmware 05, there is no such thing on it with the same bluetooth headset. Tell me what the problem is.
Stephen2010
Thu Dec 24, 2020 7:47 pm
is a newer version of android 10? I updated to Android 10 but it has been with security update since September. I still have to update the phone OTA or I have to put the software in manually. I'm not very satisfied with Android 10. to put android 9 again?
Fri Dec 25, 2020 7:13 am
Is there a choice to format when flashing
Stephen2010
Fri Dec 25, 2020 7:56 am
Well, where do I get a newer version of Android 10?
or the original version of android 9.and how to proceed if I want android 9 .what is the way
Sat Dec 26, 2020 3:36 am
Hello, which phone do you have?
Fredrik
Sun Dec 27, 2020 1:28 am
Hi, My A80 Pro currently using Android 9, is there a stable Android 10 OS available?? how can i get it?
Laurenzo
Sun Dec 27, 2020 8:43 pm
Big problem with Bluetooth on A80pro, i have installed the last Android 10 with the link give by the administrator but the phone freeze and the headphones don't work. My headphones works correctly with another phone android 10, if a patch exist for this problem, thanks.
Mon Dec 28, 2020 6:35 am
Users browsing this forum: JimmyHom, JohnnyBrine, RupertLiela and 3 guests
