junoguzman
BV9900 Pro Notification Issues (Android 9)
Fri Dec 11, 2020 8:19 pm
I've seen a few posts on this subject, but can't find a clear answer. I am not getting notifications normally for a handful of apps. Is there a way to disable whatever feature is deciding to block these? Apps added to white list will still not populate notifications.
junoguzman
Re: BV9900 Pro Notification Issues (Android 9)
Wed Dec 16, 2020 12:30 am
blackview_admin wrote:
junoguzman wrote:
Hello, which phone do you have?
I have the BV9900 Pro.
Wed Dec 16, 2020 9:26 am
junoguzman wrote:
Hello, which version do you have? 9.0 or 10.0?
junoguzman
Wed Dec 16, 2020 5:10 pm
I have 9.0 now.
Thu Dec 17, 2020 6:21 am
junoguzman wrote:
I have 9.0 now.
Put the apk into the Duraspeed too.
junoguzman
Thu Dec 17, 2020 3:42 pm
junoguzman wrote:
I have 9.0 now.
What is Duraspeed? How do I get to this?
Fri Dec 18, 2020 3:51 am
junoguzman wrote:
I have 9.0 now.
Hello, in the settings.
junoguzman
Mon Dec 28, 2020 5:29 am
There isn't anything about Duraspeed in the settings menu. Only way I can find Duraspeed is when searching in the settings menu, and nothing happens when it is pressed. How can I access this?
Mon Dec 28, 2020 6:27 am
Put the apk into the Duraspeed.
Krisztian
Wed Dec 30, 2020 12:44 pm
On Android 10 (maybe Android 9 is similar), Settings / Apps & notications / search (upper right corner) / type duraspeed and tap on the appearing green rocket icon / and tap 'Open'
