rkm_hm
Tab 8 OTG with USB-C port
Sat Nov 28, 2020 3:57 pm
I'm using a Tab 8 with docked keyboard, and would also like to use a mouse because I don't like touch pads. However, when I plug the OTG cable into the USB-C port and then plug a USB mouse into the cable, it doesn't work. It's not talking to the mouse, and the mouse light doesn't come on.
When I do the same thing on my Moto G 6+ phone, the mouse works fine.
What am I doing wrong?
Thanks,
Roger
Zoe Lin
Re: Tab 8 OTG with USB-C port
Mon Nov 30, 2020 11:26 am
Is the wattage of the USB charging cable different?
Indef
Wed Dec 30, 2020 2:18 pm
Hi, same issue here.
The USB-C port works (with an adapter to USB A, a mouse or a flash drive works as expected) only when the Tab 8 is not connected to the docked keyboard. When connected to the keyboard, the Tab 8 is not reacting when something is plugged to the USB-C port, I try with the mouse and the flash drive, and no reaction with both.
Thu Dec 31, 2020 8:16 am
This keyboard and OTG cannot be used at the same time
Indef
Mon Jan 04, 2021 5:27 pm
Oh ok, that's disappointing but can you confirm that a USB-C device (such as a mouse or a flash drive) will work with the keyboard ?
Tue Jan 05, 2021 7:44 am
No, The OTA can't be used with Keyboard at the same time.
