blackview_admin wrote:cyberfriese wrote:...
As long as the phone is still in use, the OTG function will not be turned off. I want to confirm whether you have not used it after connecting to the OTG in 15 minutes?
If the OTG option is disabled none of my audio converters are recognized and my BV9900Pro uses internal speakers.
If I turn option 'OTG' on both adapters work well for 15 minutes. Then music stops, the option is disabled and i have to enable it again. This is exact the behave what the help text will tell us. Think this is a security option.
BUT here is the missing part (a bug in my opinion):
If the option 'OTG' is disabled I just want to connect my adapter and it should be recognized by the phone to listen music with my headphone as long as i want.
Current behave makes it really hart to enjoy my sport activities. When I do my jogging, I've to go into settings menu to enable OTG to have 15 minutes joy with my music. Then I've to take a break to repeat the procedure including reconnect the adapter. That's no fun
Hope this description helps to clarify the problem?
