Apertech
USB connecting impossible
Thu Nov 12, 2020 1:47 pm
Hi
My first post here, I did buy 2 phone  for my school  : here the issue :
I cannot connect  my phone  via USB  to the Computer or
power management is OK ( batterie is loading also if I'm connected to PC)
tried several  USB cables already
really strange
thanks for your help.
Re: USB connecting impossible
Fri Nov 13, 2020 6:34 am
Apertech wrote:
Hi
really strange
The link between the mobile phone and the computer depends on whether the data transmission function of the drop-down interface is turned on
Apertech wrote:
Hi
really strange
Apertech
Fri Nov 13, 2020 1:35 pm
Ok thanks, will try this  once I can get the phone during some school holidays
fast reply :  congratulations ;)
Jodashp
Sat Nov 14, 2020 6:22 am
You have to activate the developer options then go to setting> system> developer options> default USB configuration> there select "file transfer" after that you would have to connect the phone to the computer.
