acheo
Pre purchase question about USB port
Tue Nov 10, 2020 9:48 am
It looks like the BV9900E USB port has a rubber cover on it in photos. Does it mean that water can enter the phone if the flap is open?
I have three BV9600s that have the water resistant USB port and am looking for another like that....
Best,
Adam
Re: Pre purchase question about USB port
Wed Nov 11, 2020 4:19 am
acheo wrote:
Best,
Adam
Hello, You've better to close the rubber cover if you enter the phone under the water.
Zoe Lin
Wed Nov 11, 2020 10:17 am
bv9900pro is also a good choice
acheo
Wed Nov 11, 2020 10:33 am
ok thanks. it sounds like I need to choose a different model because I don't want to the rubber flap and it sounds like water will go in if I removed it.
the BL6000Pro looks like it might be promising for me maybe I need to wait for that one.
Thu Nov 12, 2020 7:14 am
No matter what kind of product, certain protection measures are required.
