Bugstir
BV9900 Pro OTA 10/2020 Outcome
Thu Oct 22, 2020 7:54 pm
For me....All of my critical issues have gone away. Only 2 items left which is not really a big deal.
  • Auto rotate...You have to keep activating it ??
  • *86 Voicemail..On Mint (T-Mobile) this does not work. You have to change it to your full phone number. However, It keeps reverting back to *86. Will not stay once changed ?
zimzia
Re: BV9900 Pro OTA 10/2020 Outcome
Thu Oct 22, 2020 8:27 pm
After the new OTA Android 10, there is no improvement with the fingerprint (factory goodix) functionality. After placing finger on the reader, the phone will turn on the screen (it will unlock) after many seconds later over a minute, in video 1:33.
Video MEGA
or
Video drive google
After testing I noticed when the WIFI ON the phone unlocks almost normally, when the WIFI is turned off, the fingerprint works with a large large delay.
Bugstir
Fri Oct 23, 2020 12:22 am
Video MEGA
or
Video drive google
Could be an isolated case. I did not have this issue before or now with the new OTA update
zimzia
Fri Oct 23, 2020 5:13 am
Bugstir wrote:
Video MEGA
or
Video drive google
Maybe you have a other manufacturer fingerprint reade mine is Goodix, you can check by entering *#8615#
zimzia
Fri Oct 23, 2020 8:15 am
blackview_admin wrote:
Bugstir wrote:
Video MEGA
or
Video drive google
The EU version of 10.0 OTA has been opened, All Android 10.0 users can upgrade to 10.0 wirelessly.
The update does not fix the problem!!!!
Bugstir
Fri Oct 23, 2020 7:11 pm
zimzia wrote:
Bugstir wrote:
Video MEGA
or
Video drive google
Yeah....I have Sunwave...
Sat Oct 24, 2020 3:25 am
zimzia wrote:
Bugstir wrote:
Video MEGA
or
Video drive google
If your problem still can't be solved, then please contact the after-sale department directly: support02@blackview.hk
