arcnz
Call Echo
Sun Oct 11, 2020 5:23 am
When im speaking to someone they can hear themselves echo bad rather badly, I cannot hear this from the headset.
Is there a easy fix as in software ? or is this more likely to be a hardware issue.
Ive only had the phone for a week.
arcnz
Re: Call Echo
Thu Oct 22, 2020 11:29 pm
no this does not happen during hands free.
only during normal calls, if I turn the call volume to 0 only then does the issue go away for the other person. Im wondering why I can still hear them if its set to 0, is this a faulty speaker?
I have tested this by calling 2 other phones they are on different carriers, when making adjustments on the 9900pro from hands free to normal and back again when calling these other phones then problems happens exactly the same
arcnz
Re: Call Echo
Wed Oct 28, 2020 8:23 pm
No echo when on hands free, and once the in call volume is turned to 0 then the other person cant hear the echo
Build number:
BV9900Pro_EEA_S900AA_V1.0_20200601V09
robertmackiey
Re: Call Echo
Thu Oct 29, 2020 12:02 pm
To me it's sounds like the microphone on your phone is picking up what the person at the other end is saying and is feeding it back to them, is it any better if you hold the phone slightly differently or have a lower volume on the speaker.
phonebs
Re: Call Echo
Thu Nov 12, 2020 6:40 pm
Did you upgrade to Android 10 . Is the Call Echo still there on Android 10 ?
Re: Call Echo
Fri Nov 13, 2020 4:10 am
Hello, we will announce the notify if it can be upgrade.
Re: Call Echo
phonebs
Re: Call Echo
Sun Nov 15, 2020 8:11 am
On the official website  https://store.blackview.hk/en/buy/bv9900pro say: Newly Updated: BV9900 Pro is Android 10.0 Now!
It shows that new phones are sold with Android 10. Why do you state to Not upgrade to Android 10 because it is not stable?
arcnz
Re: Call Echo
Thu Nov 26, 2020 2:16 am
The issue I was having wasn't resolved after a tech person looked at the phone, so I have since sent it back to where it was purchased from and got a replacement, the new unit doesn't have the issue and all functions as normal, so was a faulty unit not a setting.
