andizg
Problems with the external sound
Mon Oct 05, 2020 10:59 am
Hi!!
Please, I need some help from you.
I have a BV9800 pro. When I bought it, all was running ok. Two months ago, the external speaker began to fail. When i try to listen to sound in spotify, for example, at the beginnning the sound is ok, but in two secods the sound dissapear. All the time was the same.
One week ago, i decided to make a factory reset, so the smartphone was like at the beginning. At that moment, everything was ok.
Yesterday, the phone began to have the same problem. From them, the external speaker does not make any sounds, in one secod, the sound dissapeared.
pascoals
Re: Problems with the external sound
Mon Oct 19, 2020 9:40 am
From today I am facing the same issue
The speaker is loose at the back if you press the back panel of the phone it works
Tue Oct 20, 2020 6:52 am
andizg wrote:
Hi!!
When there is a problem, you can press the speaker at the back and play music, May I know when the phone was purchased
mike_bv_account
Mon Nov 02, 2020 2:23 pm
Same issue, should've listen to reviews. Pressing back panel does seem to resolve it for a few second. I mean the phone's been out for less than a year, does it matter when it was purchased?
Zoe Lin
Tue Nov 03, 2020 11:15 am
This should be to replace the speaker
