tobymichelino
Tab 8 reboots itself.
Sun Oct 04, 2020 11:17 pm
Hello everyone.
After some days using My Tab 8, I'm having the following problems:
1- The device reboots itself.
( I did factory reset and cleaned apps cache but this does not work.)
2-If I update YouTube, It no longer plays at 1080. I need to use the default YouTube app in order to play HD videos.
I appreciate your responses un advance.
from MXCITY
Issadarwish
Re: Tab 8 reboots itself.
Wed Oct 14, 2020 8:41 pm
Mine is facing the same issue, hopefully get firmware update fixing it soon
Thu Oct 15, 2020 3:17 am
tobymichelino wrote:
Hello everyone.
Hello, after checking with the technical department:
The problem one is the Youtube itself issues.
The second one: please reflash the Tab8, here is the link: https://mega.nz/file/iShhnYrK#E5-tRiTpbQ84FWb_bEsAVROGQxr2ROAm9RuTJspWNqk
mw-bvfm
Sun Oct 18, 2020 4:20 pm
What is the right tool for this? There is only one ROM (* .PAC) file in the zip.
mw-bvfm
Mon Oct 19, 2020 8:08 pm
Sorry, there is no tool in the ZIP, just a * .PAC file. Do you have a tutorial?
Tue Oct 20, 2020 3:59 am
Hello, please send an email to me: mary@blackview.hk, I will send the tool to you.
natioxley
Fri Nov 20, 2020 8:39 am
My tablet also restarts even with the ROM I updated. The entire time it restarts.
mw-bvfm
Sun Nov 22, 2020 9:39 pm
I have the same problem. After re-flashing the Tab8, it reboots less often, but it happens again and again. It also does not update itself to the latest firmware, it is still hanging on the flashed ROM TAB8_NEU_P30_V1.0_20200731V02_20200732-1715.
I have the 2nd Tab8, it has no problems, the firmware update TAB8_NEU_P30_V1.0_20201029V04-20201029-1841 received it a few days ago. Is this ROM also available for download?
Is there a chance log for the updates somewhere?
mw-bvfm
Tue Nov 24, 2020 9:21 pm
There is a new version to update
Newer than TAB8_NEU_P30_V1.0_20201029V04-20201029-1841? OTA or via Flash ROM? Sorry for asking that many questions.
