cnorman27
My Flir app not working.
Wed Sep 23, 2020 6:36 pm
I just downlaoded the newest ROM from the Blackview website.  After flashing it with SP Flash Tool, everything seems to be working on the ROM except for the MyFlir app.
I keep getting a message that says "Unable to Read Camera Files".  After that, the app stops.
Is there a fix for this?  The camera was working fine yesterday!
Re: My Flir app not working.
Thu Sep 24, 2020 6:17 am
Hello, which one do you have?
cnorman27
Fri Sep 25, 2020 2:23 am
I have the BV9800 Pro.
I tried re-flashing the ROM and clearing the data on the app and it still is not working.
Fri Sep 25, 2020 7:10 am
Press *#87# and select MM1 single item to test the thermal imaging apk to see if it can be read normally
cnorman27
Fri Sep 25, 2020 9:04 pm
It will connect to the camera.  It is not a hardware issue.  Camera works find when tested.  there is some sort of problem with the software.
Sun Sep 27, 2020 9:22 am
You need to replace the APK, copy the apk to your phone, and open the apk.
Sun Sep 27, 2020 9:31 am
Can you send an email to me? I need to send the file to you to set it. My email: mary@blackview.hk
Ahmet Rüzgar
Sat Oct 03, 2020 5:05 am
Hello Admin
I had the same problem.
Myflir gave an error after the update.
To email myflir APK app:
mirahmetruzgar@gmail.com send messages
albielew
Mon Oct 05, 2020 8:00 am
Where can we get the Flir APK:?
bernardo_j
Sun Dec 06, 2020 8:11 pm
Hi Mary. All right?
Mary, I'm having the same problem as user cnorman27, my smartphone's thermal camera application is no longer working.
I've tried to do all the steps you mention in the topic, to correct the problem, but they didn't work.
Can you help me please?
I'm a civil engineer and I bought this smartphone mainly because of the thermal camera. It will be very useful in my work, if it works.
Thanks!
Bernardo Jasper
