Re: Background apps close after screen turns off - whitelist doesn't work
Fri Sep 25, 2020 8:53 am
hhan wrote:
Agreed - I am unable to figure out how to run Duraspeed. Can you give some instruction?
I went into settings to search for Duraspeed and only found that it was an app. (See screenshot) There was no way to open it and I can't find how to run the app anywhere
Sorry for this inconvenience caused to you,  could you please send this information to this email: support02@blackview.hk.
Thx a lot.
Fri Sep 25, 2020 8:54 am
Thx a lot.
hhan
Fri Sep 25, 2020 1:34 pm
I found Duraspeed!!! I have turned everything on; I'll let you know in a day or two if it works!!!
Thank you!!!
hhan
Fri Sep 25, 2020 8:35 pm
The solution of configuring Duraspeed worked!!!! Thank you so much!!!
Sun Sep 27, 2020 10:11 am
That is great
kolesar
Sun Sep 27, 2020 5:50 pm
when device is rebooted third party apps - viber, calendar, clock doesn't start by itself. duraspeed doesn't solve that. all apps have to be started manually to receive their alarms/notifiactions. all notofications are set to on.
Mon Sep 28, 2020 2:51 am
So now it can work or not?
kolesar
Mon Sep 28, 2020 6:30 am
no, it does not work. (cleaning is off, duraspeed is all on, all notifications are on)
that is why i upgraded to android 10 becouse i was hoping 10 will solve problem. even with 10 this did not work. due to all problems with 10 i downgraded phone back to 9.
mapplejoe
Fri Nov 13, 2020 5:55 pm
Thank you!!!
For those who search duraspeed :
Go to Android settings > smart assistant > duraspeed
But you need also to adjust app in Go to Android settings > autoclean
Sat Nov 14, 2020 7:15 am
Hello, sorry for the delay reply, I just missed your message, have you gotten the Android 9 back?
Users browsing this forum: srknhsgl and 5 guests
