Jamilicious
Phone syncing all the time after inserting north american card
Tue Sep 22, 2020 8:21 pm
I bought an A80pro recently when I was living in Spain and now I moved to Canada. When I insert a north American sim card the phone sync the sim card endlessly and I'm not able to use my new phone number. When I insert back the European sim card everything seems normal.
I tested the north American sim card on a spare phone and it works perfectly.
Any idea why I'm having this issue?
Thank yiu
Re: Phone syncing all the time after inserting north american card
Wed Sep 23, 2020 8:34 am
Jamilicious wrote:
Thank yiu
What kind of card is being used, and is it compatible?
Jamilicious
Wed Sep 23, 2020 2:24 pm
Nano sim card. I have no idea if it is compatible. How can I check the compatibility?
Thank you
Thu Sep 24, 2020 6:52 am
Thank you
Hello, about this problem, in order to solve it more efficiency, you'd better contact the after-sale department to check it: support02@blackview.hk.
