Treepro.Taufkirchen
phone calls interrupted
Tue Aug 02, 2016 12:36 pm
My new BV6000 first had no data connection OTA at all, but telephony worked.
After the first recommended exhaustion of the battery - 4.5 days :) and recharging it the data connection works.
But now telephony suddenly breaks, the network switches on and off, sometimes data transfer works only, or emergency calls only. This happens every 1-2 minutes – no normal call is possible! Any idea what to do?
The connection options to my PC via USB are incomplete: only the CD drive option shows up as "iAmCdRom" on the PC (Macbook Pro). The MTP or USB storage mode don't!
If I want to flash a new OS - how do I get it there?
AFAIK the OS version isn't up to date but in the menu it says "your system is up to date".
A previous post of mine from 2016.07.30 still has not been approved by the admin - why? If there is no reaction to my posts and they "disappear" I will have to take according action. I hope this is not a scam.
BV6000_Blackview_V01_20160608 - initialized 2016.07.25 :geek:
Baseband-Version MOLY.LR11.W1539.MD.MP.V10, 2016/05/16 17:29
Kernel-Version 3.18.22\root@agold1504 #10\Wed Jun 8 09:52:16 CST 2016
Re: phone calls interrupted
Wed Aug 03, 2016 7:11 am
lately we will publish a flash manual to help users to flash a new rom.
Best regards,
Admin
