nomad_mcv
BB5500 Plus charging speed
Tue Sep 22, 2020 5:54 am
Hi. I have bought the phone for its rugged properties and have found that the charging speed is slow when the phone is being used and charged at the same time. Infact, the battery drains up while charging and using it at same time too
However it charges when the phone is left alone, but the speed is terrible, it estimates 2h of charging from 70% onwards. I am using the original charger and cable
Also it does not support power bank charging somehow. the powerbank turns off after 15s which indicates the phone is drawing too low a current for normal charging. I have to enable low power charging (xiaomi powerbank) then it will charge (very slowly like originally i stated above using a ac usb charger)
Will there be a firmware update addressing this? Because i have another android 9 phone Nokia brand and it charges faster and it is rated same charge speed as the blackview (no fast charge)
nomad_mcv
Re: BB5500 Plus charging speed
Wed Sep 23, 2020 9:26 am
oic.
can i also check if this phone will receive the newest android 11?
Thu Sep 24, 2020 7:12 am
nomad_mcv wrote:
oic.
Hello, you can keep your eyes on our news.
