gscott99
PIN not working
Sat Sep 19, 2020 5:40 pm
Hi. There seems to be a fault with the Tab 8. If a security pin is set up then when the device locked, it doesn't accept the pin and stays locked. The only fix is a factory reset.
It works fine with a security pattern, but not a pin.
I see other people are having the same trouble too - https://uk.trustpilot.com/reviews/5f3e609802e85708c8d4ef05
thanks, Gordon
Re: PIN not working
Mon Sep 21, 2020 7:51 am
thanks, Gordon
Do not enter the passwords one by one, but enter the passwords continuously
gscott99
Re: PIN not working
Thu Sep 24, 2020 8:44 pm
I wrote a reply a few days ago but it seems to have vanished.
I'm not sure if I understand you correctly Admin. I am inputting the correct PIN in a normal fashion, exactly the same as I do on the other Blackview devices I have.
As you can see from the link above I'm not the only person with this trouble.
Thanks, Gordon
birnbad1
Re: PIN not working
Tue Sep 29, 2020 1:04 am
I am having the same issue when I connect the external keyboard. I have had to default it 3 times so far and the only way I can use the tablet is without the keyboard
