brendanus
BV9600E support
Mon Sep 14, 2020 7:22 pm
I have ordered the BV9600E phone. I have two questions. What is the current stock rom for this device? Is the stock rom and general support the same as for the BV9600? (I don't see a dedicated section for the BV9600E). Many thanks. I look forward to a happy relationship with my new forum!  ;)
Re: BV9600E support
Tue Sep 15, 2020 7:55 am
Good day. Thank you for your feedback. You can check this store: https://www.blackview.hk/bv9600e/
brendanus
Re: BV9600E support
Tue Sep 15, 2020 9:05 am
Many thanks!
juandi34
Re: BV9600E support
Tue Oct 20, 2020 4:30 pm
Good day:
I have a question: when can we have Android 10 update for this model ???
The real problem I have see is Notification LED colour:   cannot change notifications LED color: Always BLUE. Dont let the app (whatsapp, facebook message, emails ... etc) select its own colour. On BV9700 Pro it can, but on BV9600E cannot :( !!!!!
BV9600E User
brendanus
Re: BV9600E support
Thu Nov 05, 2020 9:09 am
aikido14 wrote:
Hi, i have bought one BV9600e as well  , and would like to update it to android 10, but before doing this would like to download the factory img of original bv9600e android system ( in case things goes wrong) , where can i download it from please ? If there is none maybe i can use the bv9600 img you provide in forums?
Hello, the Android 10 is not going to update again.
Hi, do you mean that BV9600E will get Android 10? It is currently on Android, not updated in 11 months, which is very surprising. Thanks.
juandi34
Re: BV9600E support
Thu Nov 05, 2020 10:09 am
You can download the original BV9600E firmware:
https://mega.nz/file/zWAkEShR#moCvlziap ... bvCxOptvAg
BV9600E User
Zoe Lin
Re: BV9600E support
Fri Nov 06, 2020 10:03 am
I am not suggest to update the  android 10
maybe it will effect the phone runing
Users browsing this forum: Eddiepleby, EnriqueHow, Haroldnub, RicardoGrody and 4 guests
